Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
pressure plate help needed fast!
Old Mar 26, 2009 | 05:13 PM
civic=goodgasmileage's Avatar
Default pressure plate help needed fast!
i'm in the process of taking off my pressure plate and was wondering how you take off the widget screws on the pressure plate without turning the whole clutch. i need help quicka
Old Mar 29, 2009 | 08:14 PM
lite1979's Avatar
Default Re: pressure plate help needed fast!
There should be plenty of torque on the 19mm bolt holding the crankshaft pulley on; use a 19mm socket and breaker bar to hold the crankshaft still against the A-arm or something and you should have no problem getting those widget screws off the pressure plate.
static-x
Jul 18, 2007 05:06 PM
BoOsTiN Dc2
Apr 2, 2006 02:29 PM
DOHCTOR
Aug 22, 2001 08:31 AM
