Detailing Auto Detailing and Concours
Presidential Detailed: 1991 Acura NSX - KBM
Old Mar 26, 2009 | 04:53 PM
Presidential_Detail's Avatar
Detailing Mastermind
Default Presidential Detailed: 1991 Acura NSX - KBM
After a very fun weekend at Autogeeks Detail Fest, and a very informational class with Mike Phillips at the Meguiars training class it was time to get back to work on Monday morning. I had a beautiful black NSX waiting for me! I had just received my new G110 polisher earlier last week and was dying to give it a shot with the KBM and M105 and M205 as well! As with almost every other NSX I have seen, it had super soft paint so one or two passes with M105 on a 8207 Polishing Pad using the G110 on speed setting 5 with moderate pressure for the first couple passes and then lightening up for 1-2 more passes was good for full defect removal to my surprise, but who am I kidding, I used the KBM!! :chuckle:
I have never had anything but great results using M105 no matter what method or machine I used and I was eager to try out M205. I used this with Megs 9207 Finishing Pad. It did a great job at clearing up any marring from the previous polishing step and left a pretty good finish, but I wasnt convinced it was the best finish I could get. I could pull the car into the sun, shine the halogens and there was no signs of holograms or swirls, but I noticed by using the flash on my camera the finish just seemed a bit hazy to me. This was later confirmed with one more pass using 3m Ultrafina on a 3m Finishing pad using the G110 as well, this left the finish unbelievably deep and glossy and the haziness I saw was no longer apparent. I am not by any means knocking on M205, as I believe it would be a great finishing product on maybe a little harder clear. The NSX has one of the softest clears out there, and M205 may have been just a little too aggressive to finish down completely on this particular car. Who knows, it could have been my technique being it was my first car to ever use a DA on! :waxing:
Process:
M105/Megs 8207 Polishing Pad KBM
M205/Megs 9207 Finishing Pad MPM(Thats right, Mike Phillips method, a little something we learned last weekend )
3m UF/3m UK Finishing Pad
LSP:
Optimum Opti-Seal left to cure overnight
Dodo Juice Supernatural x2
As soon as I pulled the car out it started to rain so I pulled out the EZ-UP tent and proceeded to prep the car for polishing.
This did reveal one thing to me though, this car had a TON of wax on it as it was beading quite well.
I ended up washing the car three times with Dawn Soap, twice before clay, and once after to ensure the surface was completely clean. The car was no longer beading at this point so I was happy.
I removed the spare tire so that I could better access the front compartment..
AFTER:
The engine was cleaned up as well..
Before:
After:
It was sprinkling still, which is why the airbox looks uneven, it was later touched up.
Old Mar 26, 2009 | 04:54 PM
Default Re: Presidential Detailed: 1991 Acura NSX - KBM
The car was pretty rough after removing all the oils from the previous waxes, etc.
I started with a test spot on the hood to see how much work this thing would need, and pleasantly it only took a few passes with M105/8207 to correct.
I decided this area would be best to start with..
After M105/205..the lighting makes it look worse than it really was.
As you could see here, the finish is good, but not good enough!
But after 3m UF, it looked MUCH better! You can notice the flash is more contained to itself.
So now that I had my process down, I could begin my way around the car.
Headlight Before..
After 105/205..
After 3m UF..
The center of the hood..
After 105/205..looks good right?
My camera flash tells me otherwise, I need one of those handy brinkman lights!
After 3m UF..
Old Mar 26, 2009 | 04:55 PM
I thought this area would be difficult but found it to be rather easy using the G110.
Before..
You can see the haze pretty good in this one..
After 3m UF..
Door Before..
After M105/205..I didnt manage to get a picture after UF here.
The rest of these I forgot to get pictures after UF..
I also taped off all the painted moldings to make sure they were corrected as well.
Old Mar 26, 2009 | 04:57 PM
I removed the wing to get further access to the trunk panel..those empty Autogeek boxes sure come in handy!
As you can see here, its had its days of hand polishing.
After the 105/205/UF trio.
Camera flash says its good, well see what the sun says in a bit..
Coming to an end here, my workspace.
Oh yeah, whats this thing called again?? :grinno:
Polishing finally finished, letting the Opti-Seal cure overnight.
Out in the beautiful FL sun!
These pictures were taken before the final UF finishing step. Yeah, i still wasnt happy even at this point..its a weakness.
The following pictures were taken AFTER finishing with UF.
Old Mar 26, 2009 | 04:58 PM
Some more..
Old Mar 26, 2009 | 04:59 PM
My favorite shot..
Oh yeah, Supernatural looks nice!!!
After the removing the dust from all the cracks/crevices and giving the car a final wash, I did a little mini photo shoot on my street.
Old Mar 26, 2009 | 05:00 PM
Old Mar 26, 2009 | 05:05 PM
specialblend154's Avatar
i would never drive it again. great work.
Old Mar 26, 2009 | 05:33 PM
Haha! Thanks!
Old Mar 26, 2009 | 05:45 PM
MidShipCivic's Avatar
Presidential Detail for President.
Old Mar 26, 2009 | 06:05 PM
RedRCKT000's Avatar
man i love looking at your work on cars makes me want to throw the car on the trailer and bring it down just to get cleaned by you.
.J.'s Avatar
.J.
Fun Post to read, thanks for all of the great information...
J.
Old Mar 26, 2009 | 06:26 PM
Bring it on down! :D
Old Mar 27, 2009 | 07:34 AM
98PAITR's Avatar
How long did you wait between the first and second coat of SN?
Old Mar 27, 2009 | 06:00 PM
The Collin's Avatar
Awesome work as always!
Old Mar 27, 2009 | 08:32 PM
itslogz's Avatar
Nice as always...
Just wondering, im not where near you so I couldnt get something like that done (if i was close you bet your ***) but how much do you charge for something like done to the above NSX?
Old Mar 27, 2009 | 10:12 PM
You could expect to be in the 5-800 range on a car like this.
Old Mar 28, 2009 | 10:19 PM
90sedan's Avatar
Very Nice.
Old Mar 29, 2009 | 07:01 AM
burke420's Avatar
another awesomely completed car!
Old Mar 29, 2009 | 06:12 PM
RoadRage212's Avatar
Damn...looks like I'll be ordering the Meguairs D.A. polisher kit. If you say its better than using the rotary, I'm willing to take the $200 risk. I can't believe a few of those photos. You can't even tell what color the car is because its so reflective. I usually don't give too many comments about your details because the work speaks for itself better than I could compliment it. This.... this is better than anything you've posted on this website so far. Good job. I'll let you know how the kit works for me! M105 & 205 here I come lol!!!
Old Mar 30, 2009 | 08:37 AM
You will be happy with the kit. I really like the 2.0 pads as well! Good luck and thanks for the compliments!
Old Mar 30, 2009 | 01:04 PM
builthatch's Avatar
MiG-21 superfan
this is why i keep my PC around; a DA really is nice for soft stuff. makes quick work without worrying about trails or anything.
BTW, PD, Ghoudassi said in the past that the opti-seal doesn't need any special cure time. of course it doesn't hurt, but i'm just sayin'
fantastic work brah, as usual.
Old Mar 30, 2009 | 02:42 PM
You know, up until this car I never did let it "cure", I would just go straight to wax. For some reason I decided to get on the Optimum site and forums, and they recommend letting it cure for 12-24 hours before applying a second coat. So I gave it a shot, not sure if it made a difference or not though..
Old Mar 30, 2009 | 05:24 PM
builthatch's Avatar
MiG-21 superfan
yeah i asked ghoudassi about it when i first got it because people were bagging on the opti-seal as it only really needs about an hour or so max vs. the other stuff that is out there that requires alot more time, as if that legitimizes the other products hehe...he's pretty accessible so if you ever have any questions about their products just email him. you know how crazy the detail forum people can get with their weird little habits, wives tales and obsessive processes. i swear these guys love making more work for themselves as opposed to just getting results. i just cut to the chase with david.
davidg AT optimumcarcare.com
y0- Q for ya: what is your process for engine bays such as this car? do you break out brushes and the spray bottle, towel off and then dress with hyperdressing or something? i'm curious what your typical process is for a low mileage car and/or newish vehicle.
