EG Coupe JDM Headlights and Corners
OK need some answers on these lights. What do the city lights do, and how do I hook these up? Got these in and they came with bulbs, plugs, wires coming off plugs. They have the normal headlight bulb, and also have smaller bulb in seperate hole below ( city lights ). My question is are these used like daytime running lights or what, and to what do I hook these up to? Corners are the same as US exept for the housing so no questions there.
those city lights do work as daylight running lights but you can splice them into your corner light wiring so the also blink when you have turn signals on but if you wanted to run them as DRL you just ook them up to a power source thats only constant when the key is at least on accessory dont forget to run a fuse in between
i splice the city lights into my corner lights but u have to have the key on to have them on... but if you get collor bulbs they fade fast if you do a lot of night driving so get a couple of packs of bulbs
CRXObsession
Sep 25, 2005 07:22 PM
