1997 CL both windows don't work
Old Mar 26, 2009 | 04:22 PM
Sketch_hs's Avatar
Default 1997 CL both windows don't work
1997 w/ power windows.
Both of them stopped working. Both motors tested good. Relays and fuses are good.
Is there a test for the switch? If the driver side switch fails does it knock out both switches?
As a note, the power mirror switch also doesn't work...
Old Mar 26, 2009 | 07:39 PM
notAdiesel's Avatar
Default Re: 1997 CL both windows don't work
yea find someone else with the same switch and swap them to see if it works. if you don't know anyone with the same one then try a junkyard it's probably cheap and they might let you test it first anyway. if the new switch makes them work, problem solved
if not... then idk lol
Old Mar 27, 2009 | 07:01 AM
Sketch_hs's Avatar
any other input?
Old Mar 27, 2009 | 07:10 AM
accordww's Avatar
New User
From: BAY AREA (wings west sideskirts 2dr for sale)
that's strange.. i always known the regulator was an issue but it's most likely the switch or wiring, hope you find a solution asap
Old Mar 27, 2009 | 08:40 AM
Sketch_hs's Avatar
Yeah both motors and regulators are great, work perfectly with power applied directly.
Old Apr 28, 2009 | 11:40 AM
notAdiesel's Avatar
did you test how much or that you are getting power to the switch itself? my brother's dodge needed new windshield wiper motors, even though it bench tested fine. the bench test just sees if it works, not how much power it has so it could be a weak motor
Old Apr 28, 2009 | 01:19 PM
dtapia's Avatar
master switch. pretty common do a input test for the master switch to confirm
Edward Mckenzie
Nov 23, 2013 01:26 PM
nus_dogg
Sep 2, 2013 07:44 AM
motorsports_3
Aug 15, 2010 12:25 PM
95civicoupe
May 24, 2006 06:02 PM
.David
Mar 8, 2005 12:48 AM
