Wet Floorboards Help
Old Mar 26, 2009 | 03:28 PM
harveyy's Avatar
Default Wet Floorboards Help
A female friend has a 1997 Accord with low miles. When it rains, the floor boards are soaked with water. In the begining, this problem was localized to the drivers side but now the passengers side it also wet. The drivers door seal was replaced, the windshield was recaulked professionally.
I've heard that other Accords may have experienced this water problem. Does anyone have any idea what the cause may be?
Thanks,
Harvey
Old Mar 26, 2009 | 03:38 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: Wet Floorboards Help
AC drain, should be a black rubber plug facing downwards on the firewall, it's probably clogged causing water to back up.
Search
Old Mar 26, 2009 | 04:18 PM
locosiete's Avatar
try what the muffinman says if not might have bad seal on window. but probably the ac drain
thekid2390
Jun 30, 2013 12:15 PM
BlueIntegraBoy
Aug 1, 2008 09:37 AM
adrenalinesaint
Aug 30, 2007 11:23 AM
Guaguita
Oct 2, 2006 07:08 AM
redbeardz
Jun 30, 2004 07:38 PM
