Trying to Start my 4th gen accord.....
Old Aug 13, 2002 | 05:41 PM
cokinut's Avatar
Default Trying to Start my 4th gen accord.....
Today, i tried starting my accord and it would crank and the engine would start and then immediately shut right off. The i tried to start it 3 more times and even tried jumping it. And it wouldn't start still. I came back this evening and i tried starting my car and it started just fine.
my question is, does anyone know what could cause the problem? My dad is blaming my amp (for my sub) and my fogs for sapping the battery power. Could this be an issue? Is it okay to directly connect Power sources straight from your battery? Thanks, any help would be appreciated.
Old Aug 13, 2002 | 05:48 PM
Martaigne's Avatar
Default Re: Trying to Start my 4th gen accord..... (cokinut)
No, if it turns over and manages to start before it shuts off, it's possibly a fuel problem. When's the last time the fuel filter was changed?
Old Aug 13, 2002 | 06:34 PM
cokinut's Avatar
Default Re: Trying to Start my 4th gen accord..... (martaigne)
well.....about my fuel filter; i know it hasn't been changed in the last year. How often are they supposed to be changed?
Old Aug 13, 2002 | 08:10 PM
mailforjon's Avatar
yo, ive had the same problem on a 4th gen accord and a 90 prelude that ive owned. replace the main relay under the dash. its about $45 from honda and its a bitch to get to. its the PGM-FI/MAIN relay. if youre looking for it under the dash, its up behind a small metal box next to the steering column (something for the cruise control on a MT) and it has a large "12V" printed on it and its gray with a metal mounting bracket attached to it.
Old Aug 13, 2002 | 08:15 PM
H23 Power's Avatar
Default Re: Trying to Start my 4th gen accord..... (mailforjon)
main relay
ignition coil
Old Aug 13, 2002 | 08:30 PM
cokinut's Avatar
Default Re: Trying to Start my 4th gen accord..... (01GSR)
actually, the 4th gen accords are notorious for this problem from what i've heard and they have had some recalls about it. honda said is was the ignition system (a faulty distributor to be exact). But i don't know if that's what's happening right now. It hasn't happened in like 3 months. It just makes me lose total trust in my car right now as far as reliability goes. Any other suggestions would be greatly appreciated. Thanks all you honda tekkies.
Old Aug 15, 2002 | 03:44 AM
jetli6969's Avatar
New User
i would like to know also, i got a new main relay. i am going for a new dizz, but i am thinking bout going with a different motor altogether.
Old Aug 15, 2002 | 11:14 AM
GraphiteAccord's Avatar
Default Re: Trying to Start my 4th gen accord..... (jetli6969)
my H22a car does this, i have heard sooo many stories on what's causing it. Well, y tumbler for my key is kinda worn, so i suspected it, but now i really do think its the main relay. I am going to change it as soon as i get paid...BTW, mine has been doing it for 2 years or so, and what it does is, well what it doesn't do is prime the fuel pump, so you just keep turning the key on and off, till you hear the pump prime, then it'll start.
michaelatherton
Jul 19, 2018 01:49 PM
jooanyenna
Jan 5, 2014 10:27 PM
frzr
Classic Hondas
Jan 15, 2008 09:57 PM
phiend
Mar 29, 2007 03:09 PM
ksimmons11
Oct 16, 2004 05:44 PM
