pg7 runing rich
Old Mar 26, 2009 | 01:58 PM
jbrokos307's Avatar
Default pg7 runing rich
is there anyway to lean out my obd0 dohc zc with a pg7 ecu its runin so freakin rich please help
Old Mar 26, 2009 | 02:48 PM
garageEF's Avatar
Default Re: pg7 runing rich
You could start by using the correct ECU
Old Mar 26, 2009 | 02:57 PM
jbrokos307's Avatar
which ecu should i use then
Old Mar 26, 2009 | 03:09 PM
texaszcrx's Avatar
that is the correct ecu to use, and its gonna run alittle rich, if its running extremely rich then you most likely have a problem somewhere else.
Old Mar 26, 2009 | 03:14 PM
jbrokos307's Avatar
like what else could it be there is no cel
Old Mar 26, 2009 | 04:16 PM
4drEF's Avatar
Keyboard Humorist
Is your ignition working well?
Timing set properly?
Guessing that it might not working suffiently and can't burn off all the fuel.
Compression check?
Nooch
Nov 11, 2011 03:27 PM
CjRdXmsi
Jan 3, 2006 09:54 AM
speedd2286
12
Sep 5, 2005 12:09 PM
CivicRaping
May 4, 2005 11:52 PM
