do i have a bad head?
Old Mar 26, 2009 | 12:23 PM
xwhitchx's Avatar
Default do i have a bad head?
ok i have no compresion in 1,2,3. the block is rebuilt with 0 mils on it, as for the head i got it from some one and they said it was rebuilt, but this makes me thing that he was lieing, the head is a y8, i all so would like to know how hard is it to do the valve job on it, cuz im not going to pay 200+ to get that **** done....
Old Mar 26, 2009 | 12:26 PM
hondachris1994's Avatar
Default Re: do i have a bad head?
Its very possible the head has bent valves, thats why u r not getting any compression.It is also possible that the valve lash is so tight that it isnt allowing the valves to close back all the way
Old Mar 26, 2009 | 12:34 PM
xwhitchx's Avatar
can i fix this at all?
Old Mar 26, 2009 | 12:37 PM
if its bent valves just put new valves in it. U can loosen all the valve adjusment screws then try doing another compression test to rule out the tight valves also
Old Mar 26, 2009 | 12:38 PM
xwhitchx's Avatar
yeah i did all the valve adjustments already, so i think its there bent, can i do that my self?
Old Mar 26, 2009 | 12:48 PM
^^if u have the right tools if not take it to a machine shop. U also might wanna check and see if your head and block are straight once u pull the head
Old Mar 26, 2009 | 01:42 PM
xwhitchx's Avatar
what tools do i need?
Old Mar 26, 2009 | 02:17 PM
Get a manual and it will tell u. If u dont even know what tools u need then u polly arent mechanically inclined to do it anyways. Take it to a machine shop with the new valbves and b done with it.
TravisCadello
Jun 30, 2011 08:30 AM
SirRevvs
Oct 14, 2010 10:32 AM
cbabyby
Aug 21, 2010 12:09 PM
DJYoshaBYD
Dec 9, 2009 10:59 AM
JDM00SI
Nov 9, 2005 05:26 PM
