my eg isnt starting......
ok i have been having this problem off and on for a while now. i have replaced the fuel pump, main relay, rear wiring and ignition. the fuel pump wont kick on and my gas gage drops below empty! im very confused!
can someone help me out with this one
Do you also lack bright spark at the plugs? Is the ground wire on the thermostat housing tight and clean?
The gas gauge gets its signal from the sending unit near the fuel pump in the gas tank. I think you should double check the wiring at the fuel pump. Might be a loose ground wire.
i havnt checked the brightness of the spark.....not really sure if there really is a way. and i have cleaned all grounds! i try to figure it out before asking for help but i now have nothing..lol
Check carefully the wiring for the fuel pump and sending unit (see my post above).
ok im getting power to the fuel pump but nothin........but whats with the gas gage droping below empty????? it seem like there is a shot someware.
ok i am just going to get a new fuel pump. i pulled the pump out smacked it with a screwdriver then plugged it back in and it turned on.....
ok so i replace the fuel pump with a new walbro.......and still nothing!!! what the hell!! i have power to the fuel pump!!!!! i think its time to just push it off a cliff...........
so i replaced the fuel tank "cap" where the fuel pump is attached to and it worked so i think it may be the connector to the fuel pump........not sure we will see what happens
CTR_B
May 24, 2009 02:20 PM
