Distributor problem!
ok i have a 1990 hatch dx.
inside my distributor theres a little spinning wheel thing thats held in place by a tiny screw! and for some reason that screw keeps coming off and when it does my car just completely turns off!!
today was the 3rd ***kin time it comes off and i was on my way to school and it turned off on me but i was managed to roll into the parking lot haha
i put another screw i had lying around in my car. nad it turned on just fine.
can someone please help! wat can i do to prevent this????
There is one alternative that will hold you for awhile: Drill a hole through the dizzy housing shaft where the rotor fits on. Use a cotter pin to hold the rotor in place. This worked fine for several months on my 91 Civic. Then the car started having what turned out to be coil problems. Not knowing any better, a shop replaced the dizzy housing and coil. I put in a new igniter, on their advice. In hindsight, I think the shop made the right call. I just wish I had known a little more so it had not cost me an arm and a leg for the shop's labor back in 2003. The labor is easy if one is reasonably experienced with car electrical connectors, the shop manual, a torque wrench and so on.
