Emergency Brake Help
I have an 1989 Integra that I recently took to inspection and failed because the emergency brake doesn't hold the car. I tried the adjusting screw behind the lever but it didn't work. I haven't check my rear pads but could it be that the rear pads are low and need to be changed? The car passed everything else. Any help???
Thanks in advnace.
Thanks in advnace.
If adjusting by the handle didn't help, chances are you have worn out rears. The cables could be screwed up, but they probably wouldn't have both fail at the same time
R_ACE1
12
Aug 16, 2009 12:53 PM
