94 Accord front suspension question
Old Mar 25, 2009 | 09:28 PM
AzRocket's Avatar
New User
Default 94 Accord front suspension question
As I was changing my oil the other day I noticed a dust cover boot torn to pieces. It is not the axle though. It attaches to the control arm behind where the axle comes out. Question is, what is this piece and why is there a dust boot on it, and is it easily replaced? Any pictures and/or advice is greatly appreciated. This is the best way I can describe it.
Old Mar 26, 2009 | 03:13 AM
GhostAccord's Avatar
Default Re: 94 Accord front suspension question
With out a pic, I can only guess that you are referring to the outer tie rod. It has a dust boot for the same reason all the other greased joints have them. To keep dirt out and allow them to articulate freely.
They are not hard to replace. Remove the wheel and take a look. It's one castle nut. Remove the cotter pin, remove the nut and separate the Tie rod from the knuckle. You may need a pickle fork to separate the tie rod from the steering knuckle. Then twist the outer tie rod from the inner tie rod using two open ended wrenches. Other than that you will probably require an alignment when your done. It is a fairly simple procedure.
Old Mar 26, 2009 | 04:45 PM
locosiete's Avatar
might want to check first to make sure the tie rod is still good if you are going to go threw all that first. jack up the wheel see if there is any play in the wheel other than from steering
AMS_
22
Jan 15, 2013 05:13 PM
vinuneuro
Suspension & Brakes
Jul 29, 2008 01:57 PM
professorman
Jul 21, 2006 06:37 AM
kroze
Jan 2, 2006 06:20 PM
THE LORD OF CHAOS
Nov 6, 2005 11:12 AM
