05 si greddy turbo problems
The motor in my SI just got replaced and the mechanic is having problems getting the car to run properly. It idles great but when you go to drive, it falls flat on its face. he double checked all the wiring and that aappears to be correct. He isnt pulling any errors from the computer. Does any one have a link to the kit install ? I found the manual for the 06 but Im not sure if that will work. He asked if the wastegate was positive or negative actuated, and he also asked what the timing should be set at. any help would be great.
