Civic sedan and hatchback headlights the same?
Old Mar 25, 2009 | 04:37 PM
Eli2's Avatar
Default Civic sedan and hatchback headlights the same?
Alright I have an 88 civic hatch and I found some mint 91 civic sedan headlights at the junkyard I mean they look brand new and was wondering are they a direct bolt in for my 88 hatch?
Thanks for all your help
Eli
Old Mar 25, 2009 | 04:46 PM
sde780's Avatar
Default Re: Civic sedan and hatchback headlights the same?
Nope, 88-89 fit on yours. If you really wanted to, I think you can take the 91 headlight off the brackets, then take yours off your brackets, and use the 91 headlight with your 88-89 brackets. YMMV, I remember reading about this somewhere
Old Mar 25, 2009 | 04:51 PM
Eli2's Avatar
Hmmmm interesting. Whats so different about the brackets?
Eli
Old Mar 25, 2009 | 06:01 PM
Canadian_EF's Avatar
the way the corner lights mount, for one...
other than that, not lots. i have done it.
Old Mar 25, 2009 | 06:07 PM
Eli2's Avatar
Oh then I should be fine since I have to get the corner lights anyway, See basically the only useable part on my front end is the bumper. I'm replacing the fenders, hood, getting new headlights, side marker lights, and probably a core support and oh that filler peice thingy.
So the 91 headlights with their brackets will bolt into the 88 core support.
Thanks again
Eli
Old Mar 25, 2009 | 06:08 PM
They should.
I think the only reason I swapped brackets is because the corner lights wouldnt mount right.
Old Mar 25, 2009 | 06:15 PM
Eli2's Avatar
Well thats good to know thanks alot!
Eli
KILLAB17VTEC
15
Apr 1, 2012 02:05 PM
civicb16eg
Northern California (Sales)
Apr 24, 2009 12:28 PM
spens 91 Ef
Apr 15, 2009 08:38 PM
Vovchandr
Feb 15, 2006 08:37 PM
scdarksol
Dec 18, 2003 09:44 PM
