help with d16y7 in a ek
ok so my engine broke on me, we took it down the car (2000 civic auto)
nw that i went to buy my engine from a importer i was told that i have to put my oil pump into the new engine, cause all the engines that come from japan have the sensor in the oil pump and mine is in the dizzy ???
i would apreciate any help.. thanks
To the OP, heres what you can do:
1: Reuse your USDM oil pump (If you spun a rod bearing I highly suggest you don't reuse that oil pump, even if you didn't I wouldn't neccessarily recommend it)
2: Perform the CKF trick shown here ---> http://technet.ff-squad.com/ckftrick.htm
i had the same problem with my obd1 d15b vtec in my ek, i used my old oil pump to plug up the crank sensor and youre probably gonna have to use youre old oil pan as well with that pump and the obd1 dizzy isnt going to plug up either and your old obd2 dizzy's bolts are not going to line up so youre going to need a obd1 to obd2 dizzy jumper harness
