Where to find a manual rack and pinion for a 1991 acura teg?
Ok so I have a 1991 acura integra Ls. Im trying to find a manual rack and pinion to replace my old power stering rack.. I did some research and found that some civics came with manual racks, but im not to sure if they would fit in my teggy. I also found that some first gen integras also came with manual racks but i also dont know if they will fit... If anyone has any info on this let me know.
You can use a manual rack from an 88-91 EF civic, I believe it's the closest fit but you still have to use some spacers from what I hear. The problem with the manual racks is the ratio is worse, meaning it will take more turns from lock to lock.
I just removed everything from my power steering on my DA. I gutted the valve body, looped the lines, looped the inlet/outlet on the VSS, and I'm happy with it.
J . K .
Apr 12, 2010 02:16 AM
