p30 ecu
Old Mar 25, 2009 | 03:02 PM
1994delsolLS's Avatar
Default p30 ecu
is it bad to run a p30 ecu on an ls motor without a tune and just to make sure wich car does the p30 come out of
Old Mar 25, 2009 | 03:31 PM
angel_i's Avatar
Default Re: p30 ecu
You might run lean on that ECU and its from a b16 engine.
Old Mar 25, 2009 | 03:49 PM
Default Re: p30 ecu
is it b16 type r or just like an si ecu?
Old Mar 25, 2009 | 04:07 PM
hondachris1994's Avatar
Default Re: p30 ecu
its a JDM B16 ECU
Old Mar 25, 2009 | 04:57 PM
angel_i's Avatar
Default Re: p30 ecu
Yep
Old Mar 25, 2009 | 05:26 PM
Default Re: p30 ecu
gotcha thanx
Old Mar 25, 2009 | 05:28 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Default Re: p30 ecu
Don't run a vtec ecu with a non-vtec motor,that is all.
Old Mar 25, 2009 | 05:59 PM
Default Re: p30 ecu
what does it do because i had a po6 on my ls in my del sol then i put a p30 in it for a couple days and i put the p06 back in it did i do any damage? or is it possible?
Old Mar 25, 2009 | 06:02 PM
angel_i's Avatar
Default Re: p30 ecu
Damage is anybody's guess. If its not tuned, then you might have ran it lean since 1.5/1.6L motors need less gas then the 1.8's and have different fuel/ignition maps is my guess.
Old Mar 26, 2009 | 03:10 AM
Default Re: p30 ecu
i have an ls motor that daily runs a single cam non vtec 1.5 ecu and i swapped in the dual cam 1.6 vtec ecu
Scotty_1988crxsi
17
Feb 8, 2009 09:09 PM
jdmbeegee
Southeast (Sales)
Aug 8, 2008 07:11 AM
Stray
15
Jul 28, 2007 02:34 PM
DC2tuner
Jan 4, 2005 07:05 PM
DC2tuner
Jan 4, 2005 04:34 PM
