Pro's and Con's about lighten'ed crank pulleys?
Old Aug 13, 2002 | 03:05 PM
DarkSol97's Avatar
Default Pro's and Con's about lighten'ed crank pulleys?
As the ques, says... Did anyone here anything bad about using aftermarket crank pulleys?
Old Aug 13, 2002 | 11:49 PM
kinesistech's Avatar
Default Re: Pro's and Con's about lighten'ed crank pulleys? (DarkSol97)
Factory crank pulleys have an integrated harmonic dampener. The rubber strip in the middle. I've have not ever seen and aftermarket pulley with it. Its important, especially for reliability. I would only use a factory one.
Old Aug 14, 2002 | 01:57 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Pro's and Con's about lighten'ed crank pulleys? (kinesistech)
I'm with Ryan on this one.....
Old Aug 14, 2002 | 06:29 AM
BROOD's Avatar
Default Re: Pro's and Con's about lighten'ed crank pulleys? (B18C-EJ1)
There was at least two or three threads on this very question, check them out. The search button will help you find them......
DARKTEG_
Aug 13, 2006 03:15 PM
b18junkie
10
Aug 23, 2003 09:50 AM
vtec69
16
May 18, 2002 04:04 PM
