any difference in man trans bracket and auto?
Old Mar 25, 2009 | 12:00 PM
cehcivic15's Avatar
Default any difference in man trans bracket and auto?
92-95 civic, i have 2 automatics and 1 manual civic, the bracket that is welded to the frame(yes i know they are unibody) for the tranny mount looks to be the same between the two....im wanting to change one of my autos to manual....i did this swap on an accord and had to change the bracket just wanted to be 100% sure about the civic before i started
Old Mar 25, 2009 | 12:42 PM
CivicSpoon's Avatar
Default Re: any difference in man trans bracket and auto?
The brackets are technically the same, but they are in different places. I believe the bracket on the automatic chassis is closer to the firewall. Hasport makers a mount for this conversion, other companies might as well. Or you could just cut off the bracket and reweld it in the right place.
Old Mar 25, 2009 | 01:15 PM
94EG8's Avatar
Seagull Management
you're partly right, the automatic bracket is about half an inch closer to the firewall. Its a different bracket though, its angled up as opposed to going straight out. Either buy an aftermarket auto to manual conversion mount, or cut and weld the manual pocket mount to the frame rail.
Old Mar 25, 2009 | 02:14 PM
jdmwannabee's Avatar
+1
funny *** sig
JDMchucko
Apr 27, 2011 03:32 PM
sorrule
Sep 24, 2008 07:36 PM
95 honda8
Aug 2, 2007 04:29 PM
Timmay
10
Aug 18, 2004 07:41 PM
