d16 alternator on my h22a
Old Mar 25, 2009 | 11:44 AM
lude98SH's Avatar
Default d16 alternator on my h22a
Well I have the ESP bracket and the alternator. Since the plugs for the h22 alternator and the d16 alternator are different. I have a plug off a civic that works that I may to splice to make this work. Ideally I wanted to make it plug and play somehow where I do not have to splice or cut wires on my stock harness. So i would need a plug of some sort I guess the female side on the h22 alternator or something like that and run that to my plug. Has anyone done this or attempted it ? Or have an old h22 alternator that does not work that I could buy for parts ?
Also I was contemplating running a 6 rib alt pulley that I have laying around vs the stock pulley. Does anyone know if they saw any minimal differences with the decrease in rotational mass found there ? Im alittle weary of running a 3 rib belt on a 6 rib crank pulley.
Old Mar 25, 2009 | 12:49 PM
Hawkze_2.3's Avatar
Default Re: d16 alternator on my h22a
The 3-rib belt should be fine unless you make a lot more than stock hp. Have any pics of the alternator plugs?
Old Mar 25, 2009 | 04:45 PM
lude98SH's Avatar
ill take some to give you a better idea.
Old Mar 25, 2009 | 07:42 PM
jlude90's Avatar
open the alternator and put the proper plug in. its just nuts bolts and screws, very easy
Old Mar 25, 2009 | 07:44 PM
lude98SH's Avatar
so your saying swap the plug out of the d16 alternator and put the h22 plug ?
Old Apr 1, 2009 | 09:02 PM
lude98SH's Avatar
The bottom picture is a d17 alternator but its the same plug as an h22 alternator.
Old Apr 1, 2009 | 09:03 PM
lude98SH's Avatar
So your saying the plug comes right out ?
Old Apr 2, 2009 | 11:43 AM
jlude90's Avatar
o wow, i forgot the pllugs were THAT different, i'm not sure if the plugs will swap. it would probably be better to just swap the plugs on your harness then, looks like it'd have to be a cut/solder job as well, i don't thing a de-pin would work
Old Apr 2, 2009 | 12:54 PM
Hawkze_2.3's Avatar
Yeah, if you can de-pin and re-pin the connector that would probably be best. Otherwise you might have to cut and solder wires like jlude90 said.
Does each connector have the same number of wires? Looks like they do...
Old Apr 2, 2009 | 03:13 PM
lude98SH's Avatar
yes, but different colors. I wanted to try and make this plug and play if i could. I would need a plug from an h22 alternator i guess
Turbo O
Mar 30, 2006 09:19 AM
SixguN
Apr 2, 2005 12:20 PM
superturboprelude
Mar 18, 2005 05:14 PM
ProjectLudeSiR
Sep 2, 2004 11:01 AM
