HELP: CEL# po505 - idle control (99 Si B16)
Old Mar 25, 2009 | 07:54 AM
theshamgod's Avatar
TRIAL USER
Default HELP: CEL# po505 - idle control (99 Si B16)
idling is fine once i start the car. later in the day while driving, idling will be at about 1500 and has trouble getting past 1700 when accelerating slowly. the needle and engine will just go back and forth between 1500-1700. i can get past it by applying more gas, and it will seem to run fine. the check engine light is on, and now its bothersome cruising at low speeds, because i cant without being past 2000 or so.
discovered the CEL# is: po505 - idle air control.
suggestions to fix?
Old Mar 25, 2009 | 08:18 AM
angel_i's Avatar
Default Re: HELP: CEL# po505 - idle control (99 Si B16)
check for vacuum leaks man. Try replacing your pcv valve..
LadySi2000
Aug 15, 2013 06:39 PM
zenon8890
Mar 30, 2010 04:18 AM
mikester1222
Apr 18, 2008 06:55 PM
JDMkidGSR
Nov 15, 2005 04:59 AM
RFd15bhatch
Aug 22, 2005 03:52 PM
