B17 ?? hp
ok i was lookin on here and didnt find anything about anyone building up a B17..i was wondering what hp people made with CTR pistons... or jdm itr's
im going with
ctr cams
todda flywheel
portd n polish gsr head
spoon head gasket
skunk2 intake mani
let me know what u guys think about the pistons ctr or itrs
im going with
ctr cams
todda flywheel
spoon head gasket
skunk2 intake mani
Basically this is a poor man's CTR with 80cc's more displacement, and 1000k red-line loss. I'm thinking 150 or less to the wheels. (unless you tune).
And you are looking at compression in the high 12's:1 which is way higher than ctr cams need.
can you buy 94 or higher octane? I would use the JDM type R pistons, they will give you a more detonation friendly 11:1
and tune it! those components were not indented to go in to that engine!
Have you researched what your C/R would be with either piston,machining that might be done to the head or block, and with the HG your planning to use?
i was going to go with a spoon head gasket .. and i can run 93... or 110 they sell it at the gas station.. or E85.. what that eats away the rubber seals
im trying to have around 12:0 comp...
I concure
