FS:CT: JE pistons, big brake kit, block guard, other...
i have:
~STR B series block gaurd. new never used. $90
~a tenzo-r big brake kit for 90+ integras, and i think 92-00 civics ex+si trim only. Big Brake drilled and slotted rotors are made for use with stock brake system and are ABS compatible. Comes with lightweight CNC-machined billet aluminum rotor hats. rotors are 12+" diameter. Recommended for 17" and larger wheel diameters-will fit some 16" as well. Comes with all necessary hardware. The set i have is black anodized. they are new,only test fitted to my civic VX, and did not fit. i have since sold the car, and already have these on my integra. they work great on that car.$300
used DC 4>2>1 ceramic header. two piece design. i have all the original bolts/gaskets that came with it. upgraded to a newer header. slight surface rust, NO dents or cracks at all! came off my ls/vtec in the integra. $60
JE forged pistons, brand new in box. custom designed for big bore ls/vtec engine. 85mm bore. with all rings and wrist pins & locks. $500 or possible trade. build specs available upon request.
2 front OEM crossmembers 90-93 teg. $20 each
2 Nitto NT555 tires. 205/40-17 . very good condition. 90+% tread left (will have to look when i get home)$120 for the pair
OEM power steering rack. $30
radiator support.not bent. $20
brake booster$20
i have many other OEM parts, from my spare shell. two complete, mint dashes. black. please inquire.
most prices negotiable, will ship at buyers expense, or meet you somewhere local. i am in east CT. close to RI. please PM or email. lots of pics available as well. thnx.
~bryan
garmonb@zhi.com
brake booster$20
~bryan
garmonb@zhi.com
fxrob
Aug 1, 2007 03:40 PM
rollingCULTURE
17
Jan 23, 2006 09:52 AM
indyjones
May 5, 2004 12:01 PM
