looking for the clear yellow spray paint for headlights
Old Mar 25, 2009 | 05:42 AM
boostedgsr1234's Avatar
Default looking for the clear yellow spray paint for headlights
like the tittle says, i found it on inline4.com for like $35, and i just need a little bit to do my high beams, anybody have a can they would sell??
Old Mar 25, 2009 | 06:27 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: looking for the clear yellow spray paint for headlights
Krylon, Find a hobby store that sells transparent/stained glass paint.
It's around $6 a can, more then enough to do your highbeams and more.
Old Mar 25, 2009 | 03:04 PM
babiboidb1's Avatar
Old Mar 25, 2009 | 03:10 PM
SuckMyDOHC's Avatar
i think it looks ugly painted. if you really want yellow high beams, why not just get yellow 9005 bulbs?
http://www.luminicsbulbs.com/9005_bulbs.php
Old Mar 25, 2009 | 06:28 PM
Armorzaku's Avatar
cause i dont think he wants to cruise around with his high beams on, hahaha he just wants the style
Old Mar 25, 2009 | 06:53 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
To each his own.
Old Mar 25, 2009 | 07:01 PM
honda_guy_07's Avatar
just do it the right way just get some H.I.D's that burn yellow
Old Mar 25, 2009 | 11:46 PM
SuckMyDOHC's Avatar
huh?
Old Mar 26, 2009 | 04:09 AM
JDM 98 GSR's Avatar
buy laminix
Old Mar 26, 2009 | 08:11 AM
DrGrEeNtHuMb's Avatar
I do mine permanently by first scuffing my headlights(both lows and highs) with like 1000 grit. Then I wax and grease remove them, then spray with a few coats of good clear. Then I let them dry good and sand them with 2000 grit, again sanding both sides. Next you mask off the lowbeam and spray highs with sunshine yellow candy until the desired tint is acheived. Then I unmask the low and re clear the whole headlight. Looks like these
then clear
Then sand again and finish!
Old Mar 26, 2009 | 08:25 AM
thats how i plan to do it if i can find some transparent yellow paint first
Old Mar 26, 2009 | 08:37 AM
popularbelief's Avatar
it's a great project but your seriously not getting the life out of it. the yellow hid trick is a much longer trick. i agree with the grit and waxing/buffing technique. i recently purchased a 3m kit for $15 @ advance auto. used my hnad drill on low rpm and it works majestically. added the hid kit and my visibility increased by 50%.
gl to you and always be safe bc headlights are not joke to mess up.
Old Mar 26, 2009 | 08:50 AM
This isn't a wax/buffing thing. It real auto clear and auto paintm waxing or polishing only lasts about a year. I cleared mine first and let them dry then sand the clear and paint yellow so that the yellow doesn't get embedded into the actual plastic on the headlight. It has that layer ofclear under it so if I decide to take the yellow off I can just wetsand it a lil and will come right out without sanding more plastic off my headlight. I love painted headlights cuz bulbs are gay as **** and not everyone can do a hid. Its the pure fact of a yellow lense that people find the freshest(unless u like bulbs...) my 2 cents
Old Mar 26, 2009 | 04:08 PM
^^^so what yellow paint did you use? where did u get it?
Old Mar 26, 2009 | 05:17 PM
shawndb1's Avatar
Originally Posted by JDM 98 GSR
buy laminix
x2
that's what I used on my dc4... was 16.16$ already pre-cut to our highbeams
Old Mar 26, 2009 | 06:12 PM
The paint is made by house ofkolor and is called sunshine yellow candy, and for clear I used PPG dc3000 clear. You can pick it up at your local car paint store. Not autozone or napa but an actaull paint store
Old Mar 26, 2009 | 09:12 PM
dc2teg06's Avatar
eeew yellow high beams... ricer : )
....but seriously GO the LaminX route. If you ever do get sick of them it is REMOVABLE. Krylon is what I used, and I'm regretting it because I no longer want the yellow highbeams. If you really don't care just paint it with some Krylon Transparent paint from a craft store. If you change stuff up a lot, and this whole JDM trend suddenly becomes uncool you'll wish you had LaminX.
Old Mar 26, 2009 | 11:50 PM
Jimmy's Avatar
Global Moderator
http://www.lamin-x.com/
Old Mar 27, 2009 | 06:40 AM
Boosted Italian's Avatar
I know this is Integra only and **** but I was looking for something else and came across this theard and I did the Lamin-X Route on my s2000 It is a awesome product easy to install, pre cut to fit, package nice when you do get it! With my HIDS on it does dim it just a bit fyi!
This is what it looks like on my s2000!
Old Nov 4, 2009 | 07:21 PM
lao-boy503's Avatar
hey i want to make my integra high beams yellow but i cant find a store to get the paint. can someone help me find a place to get paint or the film for it
thanks
Old Nov 5, 2009 | 01:44 AM
ohsojdmdc's Avatar
go to your local sticker/sign shop and get a sheet of laminate or vinyl in transparent yellow thats what i did and you can peel it off if you end up not going for that look anymore
Old Nov 5, 2009 | 06:00 AM
TonySemi's Avatar
Around here, Jake the snake will pull you over for that (cruisin with HB HID's on) and its not a cheap ticket, also chk local state inspection laws. Just a suggestion. ( go with the LAMINEX, you get the look you want and is removable)
Old Nov 5, 2009 | 06:02 AM
TonySemi's Avatar
thanks
Advanced auto parts, and pep boys
Old Nov 5, 2009 | 11:44 AM
mmoore9700's Avatar
Use the Lamin-x, I used it on my fogs. Very happy with it.
Old Nov 5, 2009 | 11:59 AM
josh-roy's Avatar
Shinzowerks.com
