***90 Integra Slammed on BBS's w/ Built Motor***
I got a 1990 Acura Integra 4 door, car is clean for original body. Has some rust on driver side quarter panel but other than that car is very clean.
There is alot of work put into this car that got it to the point that it is now. Im asking $2800 obo. Between motor work and suspension is close to $2000. Best way to reach me is either PM or call/text 203-247-4526....if i dont answer leave a voicemail or pm wit your number and ill get back to you asap. Im also located in norwalk,ct about 20min from the bronx
Motor:
B16a2 (2000 si)
built head
street port and polish done by advanced motion in NY
milled .010
3 angle valve job
supertech springs
KMS retainers
omnipower valves
bronze valve guides
arp headstuds
all new seals
new head gasket
I have all reciepts for the labor and parts total over $1000
gates timing belt
ctr crank pully
new NGK spark plugs and wires
DC sports header
no name catch can
brand new radiator hoses
b&m fuel pressure gauge
Tranny:
ACT clutch
S1 jdm b16 cable tranny out of a -90'-93' jdm DA6 Xsi:
heres the gear ratios its probably the best tranny next to the itr but no lsd
RSi/XSi, S1 J1, Cable,
1st- 3.230
2nd- 2.105
3rd- 1.458
4th- 1.107
5th- 0.848
rev- 3.000
final- 4.400
Suspension:
ground control coilovers
kyb agx adjustables in front
monroe sensatrac adjustables in rear
blox camber kits
blox lower control arms
Wheels:
rare mint bbs wheels with bbs centercaps
new hankook tires 195/50/15
Exterior:
Fresh 50/50 tailights
antenna delete plug
jdm 1pc black housing headlights
jdm amber turn signals
Interior:
seats and carpet are mint
jdm xsi gauge cluster
gsr shift ****
Car currently has a PR4 ecu in it but im throwing in a JDM da6 xsi obd0 PWO ecu that has vtec crossover at 5k and redline is 8200.
The bad:
Linkage is tight because its from a crx so its a lil bit shorter than its suppose to be but you can still drive it fine.
The car needs to be wired for the knock sensor.
Needs a new ignition but might be replaced
None of these affect the car from driving but its just a couple lil things that need to be done.
Motor:
B16a2 (2000 si)
built head
milled .010
3 angle valve job
supertech springs
KMS retainers
omnipower valves
bronze valve guides
arp headstuds
all new seals
new head gasket
gates timing belt
ctr crank pully
DC sports header
no name catch can
Tranny:
ACT clutch
1st- 3.230
2nd- 2.105
3rd- 1.458
4th- 1.107
5th- 0.848
rev- 3.000
final- 4.400
Suspension:
blox camber kits
Wheels:
Exterior:
antenna delete plug
Interior:
gsr shift ****
The bad:
interested in a trade for a 2006 yamaha banshee 350cc 4 wheeler?bought it brand new in 06' for $6400.blue book is still around $4500.
http://i718.photobucket.com/albums/w...IMG00259-1.jpg
http://i718.photobucket.com/albums/w...x/IMG00260.jpg
http://i718.photobucket.com/albums/w...x/IMG00261.jpg
http://i718.photobucket.com/albums/w...x/IMG00262.jpg
thanks but no thanks, not really lookin for a 4 wheeler......gd looks on all the bumps
HondaH22a#1
Jun 9, 2009 11:56 PM
k00lt1nt
Nov 29, 2007 03:52 PM
0260MOTORSPORTS
Sep 20, 2007 12:27 AM
overdose
May 27, 2005 07:34 AM
