dohc zc
Old Mar 24, 2009 | 09:06 PM
89CRXProject's Avatar
Default dohc zc
what is the difference between the obd0 zc (88-92) compared to the obd1 zc (92-95) other then the obd and the year?
thanks for answering my stupid stoner noob questions
Old Mar 24, 2009 | 09:33 PM
D16SiHatch's Avatar
Default Re: dohc zc
http://www.d-series.org/forums/dohc-...arts-list.html
you're welcome
Old Mar 25, 2009 | 07:33 AM
jlicrx's Avatar
Default Re: dohc zc
different intake manifold, throttle body and fuel rail (OBD1 injectors) with MAP sensor on the throttle body (OBD1 will accept the larger B-series throttle bodies) - different cooling fan switch location - different distributor (OBD1 has the cylinder sensor in the distributor, so it doesn't have the sensor on the end of the exhaust camshaft) - OBD1 has different crank pulley and alternator which uses the 4-rib belt instead of the 3-rib belt like the OBD0 - different driver's side engine mount (OBD1 has mount like EG and OBD0 has mount like EF)
Old Mar 25, 2009 | 08:04 PM
Default Re: dohc zc
thanks for extensivly answering my questions, so does that mean i would need to buy a special mount from hasport or something to put the obd1 zc in my ed8 crx?
Old Mar 25, 2009 | 08:10 PM
DOHCED8's Avatar
Default Re: dohc zc
not unless u convert to hydro
Old Mar 25, 2009 | 09:00 PM
Default Re: dohc zc
then what is the difference with the driver side motor mount? i cant find anything on this
digitalcongo
Jan 22, 2014 05:11 PM
D7_62
Classic Hondas
Aug 6, 2012 07:36 AM
92lxsleeper
Jul 6, 2009 07:24 PM
jtmoney2002
Aug 25, 2008 04:43 PM
97grnrs
Dec 10, 2006 04:14 PM
