d16a1 specs?
what kinda vehicle you putting the possible d16a1? My 89 integra comes with it stock its a tourqe monster i love it
D16A1
Found in:
1986-89 Acura Integra (USA)
Displacement : 1,590 cc (97 cu in)
Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
Valvetrain : DOHC (? valves per cylinder)
Fuel Control : OBD-0 MPFI
1986-1987
Compression : 9.3:1
Power : 113 hp (84.3 kW, 115 ps) @ 6250 rpm
Torque : 99 ft·lbf (13.7 kg/m, 134 Nm) @ 5500 rpm
Piston Code: PG6
1988-1989
Compression : 9.5: 1
Power : 118 hp (88.0 kW, 120 ps) @ 6250 rpm
Torque: 101 ft·lbf (14.0 kg/m, 137 Nm) @ 5500 rpm
Piston Code: P29 (Equivalent to PM7)
info from wikipedia
D16A1
Found in:
1986-1987
Compression : 9.3:1
Piston Code: PG6
1988-1989
info from wikipedia
what about 99 or 101ft/lbs is a monster? im pretty sure that puts it in the kitten range. my 86 Jetta turbodiesel made 92ft/lbs, it certainly was not a monster. it just made more racket doing it.
