tdc
Old Mar 24, 2009 | 07:29 PM
1012iaj's Avatar
New User
Default tdc
hi, I am about to dial in my cams on b20/vtec with high comp. pistons and skunk2 pro2 cams. the problem I am having is finding absolute tdc or true tdc as some might call it. Does anybody know how to do this with a dial indicator? my head is already installed. any info will help thanks.
Old Mar 25, 2009 | 10:23 AM
Rocket's Avatar
Default Re: tdc
1. You need a degree wheel and eyeball TDC and set your wheel.
2. Measure 0.100 down on either side of TDC.
3. Absolute TDC will be in the exact middle of your two numbers.
EG. if you 0.100 down is 22 BTDC and 20 ATDC then TDC is on 1 BTDC.
4. Adjust needle to 1 BTDC, then adjust wheel to 0.
Old Mar 25, 2009 | 03:33 PM
1012iaj's Avatar
New User
Default Re: tdc
thanks, is it possible to do the piston stop method on a bseries? if so how is it done?
Old Mar 25, 2009 | 03:42 PM
DonF's Avatar
Default Re: tdc
Yes, easy way, take an old spark plug, knock out the center, tap it for a long 5/16 bolt, round the end and have at it.
b1620vtec
19
Oct 25, 2014 02:18 AM
MarkOlson
May 29, 2011 11:12 AM
saintspall
10
Dec 19, 2006 11:41 AM
DEMNTD1
Jul 21, 2005 04:40 PM
desert eagle
10
Jan 22, 2004 06:53 PM
