97 teg piston 3 misfire
Old Mar 24, 2009 | 04:17 PM
phoenix97teg's Avatar
New User
Default 97 teg piston 3 misfire
hey guys i have a 97 teg rs the other day when i started my car it started idling weird(like it wanted to shut off) and then the check engine light started to flash off and on, then juss stayed on. the ecu code read piston 3 misfire. the following day on the road when i accelerated the rpm gauge worked fine but the mph didn't react properly. and once again idled weird. my buddy said all i needed was a tune-up spark plugs, cap and rotor things like that. any suggestions?
Old Mar 24, 2009 | 07:31 PM
j_bizach's Avatar
Default Re: 97 teg piston 3 misfire
I'd agree with him a tune up of ur igniton system usually fixs that problem. Cap, rotor, plugs (ngk), and wires im sure shell be running like a champ again.
Old Mar 24, 2009 | 08:45 PM
rhino87's Avatar
something similar happened to me a while back....did you wash your engine? Because if you did then maybe water got down to the spark plug, that's what happened to mine.
StreetsideStig
Sep 28, 2012 05:48 AM
scuffler
13
Oct 2, 2010 03:07 PM
Dukes69
May 13, 2007 12:44 PM
hondaowner
Apr 6, 2004 04:42 AM
