Radio problem: Radio stays on after key is removed
I just installed a new clarion unit in my 97 civic. I took out my old sony and wire harness, and then just matched up the wire colors with the clarion harness, pretty straight forward install. Everything seemed to work fine until i took the key out of the ignition. The head unit was still on and playing the cd! The only thing I could do for right now is turn the head unit off with its power button. Does anyone know what the problem is? Thanks
Recheck your wiring, make sure that the HUs blue or blue/white, [amp/power ant. control] lead is not connected to a constant power. 94
i figured it out. seems that the acc wire was cut open a bit from the install and it was grounding out. i just taped it and carefully put it back. thanks for the help guys
mickey513
Audio / Security / Video
Jun 1, 2002 06:54 AM
