Honda S2000 Honda S2000
What is the R/S ratio of the F20C?
Old Aug 13, 2002 | 01:09 PM
Black R's Avatar
25 Year Member
Default What is the R/S ratio of the F20C?
What is the R/S ratio of the F20C (S2000 engine)? Find that out, then ask yourself, why would honda make it so? Couldn't they have made more torque from a longer stroke??
.....quoted here to get answers. The above is not my statement, but I am now curious.....
Old Aug 13, 2002 | 01:11 PM
jerrypeterson's Avatar
Default Re: What is the R/S ratio of the F20C? (Black R)
Yes they would have made more torque with a longer stroke, but they couldn't really recommend a 9000rpm redline as a result.
Old Aug 14, 2002 | 09:10 PM
brainwo's Avatar
New User
The S2000 got a R/S ratio of 1.81
Old Aug 15, 2002 | 11:18 PM
evil vapor's Avatar
Default Re: What is the R/S ratio of the F20C? (brainwo)
pretty close to an ideal ratio of 1.75
Old Aug 21, 2002 | 02:18 PM
EBP_SI's Avatar
Default Re: What is the R/S ratio of the F20C? (vapors2k)
isn't the B16A2 1.74???
Old Aug 22, 2002 | 03:12 AM
evil vapor's Avatar
Default Re: What is the R/S ratio of the F20C? (EBP_SI)
yep...it's a motor with ideal bore/stroke ratio.
Old Aug 22, 2002 | 07:31 AM
Muckman's Avatar
Moderator in Chief
please explain where this ideal 1.74 Bore/Stroke ratio came from - and who says its ideal
Old Aug 22, 2002 | 11:52 AM
brainwo's Avatar
New User
Default Re: What is the R/S ratio of the F20C? (Muckman)
Check out http://www.theoldone.com/archive/
But Ideal.. What is ideal anyways?
And what's not?.. hmm... ..
Old Aug 22, 2002 | 05:26 PM
evil vapor's Avatar
ideal means a perfectly square bore to stroke. When the bore to stroke is ideal, the stresses on the crank/rod/piston assembly are the lowest.
Old Aug 23, 2002 | 04:31 AM
Rembrant Q. Einstein's Avatar
we are talking about the rod to stroke ratio. a square bore and stroke means they are the same measure, like 86mm x 86mm like the K20. oversquare means a bigger bore than stroke, undersquare longer stroke than bore. THERE IS NO ideal bore to stroke ratio: F1 cars have a bore/stroke ratio over 2:1, and are designed by geniuses from the ground up to be the highest NA ouput engines in the world. The Honda Insight, the most efficient car in the world, has a bore to stoke ratio of 0.88:1.
Higher revving MODIFIED engines have shorter strokes to allow lower piston speeds and acceleration with longer con rods, and have larger bores to compensate for the displacement loss without significantly increasing reicprocating weight. Bigger bores allow bigger valves for better VE at higher engine speeds.
Old Aug 24, 2002 | 05:54 PM
Westrock2000's Avatar
Default Re: What is the R/S ratio of the F20C? (Rembrant Q. Einstein)
its rod length to stroke dimeter, the bore has nothing to do with it...if you bore out a b16 to 84mm, you get almost 1.8L but still maintain the 1.75 r/s ratio.
Old Aug 24, 2002 | 08:04 PM
Default Re: What is the R/S ratio of the F20C? (Westrock2000)
Yes i know....but he was talking about bore/stroke ratios, and I was talking about the insignificance of them.
I mentioned MODIFIED engines that are de-stroked (allowing longer rod) and bored to compensate displacement for the shorter stroke. I was describing the total engine package.
Old Aug 25, 2002 | 01:07 PM
HXMan's Avatar
With a higher R/S ratio you get lower crank to rod angles(good for motor as less side loading on piston results in less wear), and high rpm breathing capability improves.
Old Aug 25, 2002 | 10:33 PM
ryu12341's Avatar
can u bore a b16 out to 84 mm without resleeving it?
Old Aug 26, 2002 | 07:03 AM
Black R's Avatar
25 Year Member
Default Re: What is the R/S ratio of the F20C? (ryu12341)
Hell no! 82mm bore MAX without resleeving... That's a thin-walled cylinder too... Don't even think about FI on it then...
Most people just keep the b16 head and use the b28 block, route oil lines for vtec, and done!
MrdVVb
K Series
Mar 14, 2015 12:12 PM
mgags7
Honda S2000
Apr 3, 2007 08:07 AM
HeikDiesel
Feb 19, 2005 07:58 PM
hitekper4mance
Jul 30, 2002 05:14 PM
austrian type-R
Apr 15, 2002 08:59 PM
