Car still won't start
Old Aug 13, 2002 | 01:07 PM
Malgerus's Avatar
Default Car still won't start
Well, I'm running out of options and luck.
The distributor is good, the fuel pump is good. Just tried another ECU... made no difference. The car cranks but will not catch. There is spark, gas, and air but it just won't catch. Any suggestions?? Someone told me the coolant temperature sensor, but I don't see how that would affect it. Any other sensors to check?
Old Aug 13, 2002 | 02:21 PM
Chiovnidca's Avatar
Default Re: Car still won't start (89_Y_49)
Is the cam in time?
Old Aug 13, 2002 | 03:19 PM
Turbo Powa's Avatar
Default Re: Car still won't start (Chiovnidca)
Did you try a compression test?
Old Aug 13, 2002 | 03:52 PM
Malgerus's Avatar
Is the cam in time?
well, as far as I can tell, it is. I have an AEM camgear on it right now and it's difficult to see if it's lined up properly. However, I never touched it from when the car was running perfectly. the compression is 185 psi (cold) 215-220 across when it was running.
Old Aug 13, 2002 | 03:57 PM
Chiovnidca's Avatar
How much fuel presure do you have?
Old Aug 13, 2002 | 04:02 PM
Malgerus's Avatar
Don't know the exact psi, but the spark plugs are drenched in gas, and it's a brand new holley 190 lph pump
Old Aug 13, 2002 | 04:07 PM
Chiovnidca's Avatar
It's flooded. Take the plugs out and let the cylinders dry out overnight.
Old Aug 13, 2002 | 04:16 PM
Malgerus's Avatar
hey ok, I'll give that a shot. Thanks!
boostedcivichatchbacksi
Aug 21, 2021 10:38 AM
Rubenjames25
13
Mar 6, 2014 11:55 PM
ketchup
Jan 30, 2009 01:55 PM
kasso
Mar 23, 2006 01:38 PM
BeavisB16
Jul 27, 2003 11:30 AM
