how to change tranny oil
Old Mar 24, 2009 | 11:49 AM
sublimeh215's Avatar
Default how to change tranny oil
can someone tell me how to drain and change the oil on my tranny???
Old Mar 24, 2009 | 11:50 AM
Default Re: how to change tranny oil
its on a 1990 honda civic dx. 5 speed
Old Mar 24, 2009 | 12:01 PM
dephtone's Avatar
There is a drain plug on the underside of the trans, it's a 17mm bolt. Remove this, it will drain out. Replace the plug. Refilling the trans you can do one of 2 things, you can use the filler hole right next to where the clutch cable is. this is sometimes capped off, it's a tube that sticks up about 2 inches or so off the trans. Or on the side of the trans, iv seen people use the fluid check hole to fill their trans. You can refill the trans with 30w oil or synchromesh or you can buy honda MTF from any dealership.
Old Mar 24, 2009 | 12:11 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
You want to make sure you can get the filler plug
loose before you drain it..
There are some pics posted here of the
drain,filler hole,and alternate locations to add fluid:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-how-change-tranny-fluid-1325930/
Old Mar 24, 2009 | 04:39 PM
detuned's Avatar
in case no one bothers to read the other post, 2 quarts of fluid. i had the same question.
ejpogi1925
Oct 2, 2008 03:08 PM
the_rex
11
Apr 9, 2008 05:26 PM
EF-Boy91
Oct 8, 2006 05:22 PM
92civiclx
Jun 30, 2003 01:00 AM
4doorLX
Oct 2, 2002 10:55 AM
