What timing belt/water pump tensioner fits 95 b18b
Old Mar 24, 2009 | 10:39 AM
woadiestyle's Avatar
New User
Default What timing belt/water pump tensioner fits 95 b18b
will a gsr timing belt, water pump, and tensioner fit on a b18b? even tho the part numbers are different?
......also will a b16a timing belt, water pump, and tensioner work on a b18b?
someone says all b series is interchangeable and is selling what i need. thanks for any help
Old Mar 24, 2009 | 11:00 AM
bmwpride's Avatar
Default Re: What timing belt/water pump tensioner fits 95 b18b
any b series will work, not sure about the tensioner though
Old Mar 24, 2009 | 11:18 AM
super jdm yo's Avatar
i think the difference is going to be with vtec and non vtec. because i know the type r/gsr has more teeth on the water pump then a ls one. so with that you're going to need the corrasponding timing belt and tensioner. correct me if i'm wrong but i know there's a difference. good luck with this
Old Mar 24, 2009 | 02:18 PM
seanbev24's Avatar
The belt has to match the water pump for sure, I don't think the tensioner matters but don't quote me on that one.
Old Mar 24, 2009 | 06:26 PM
egsleepercivic's Avatar
95 LS parts will work
Old Mar 25, 2009 | 11:37 AM
Tommy_T's Avatar
use the ls parts. the vtec parts are different besides the tensioner.
Old Mar 25, 2009 | 01:09 PM
seanbev24's Avatar
Yes the vtec parts are different, but they will work just fine. The 22 tooth gsr water pump is better than the ls. GSR water pump, use GSR belt. LS water pump, use LS belt. B16 belt won't work, different block height.
Old Mar 25, 2009 | 04:06 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
This is correct. The VTEC water pump is better because the pump turns slightly slower, which pumps the fluid through better (less possibility of cavitation).
thirsk66
10
May 22, 2013 02:26 PM
ALLMOTOR CRX
Mar 5, 2007 05:43 PM
1slowcrx
Nov 17, 2004 03:24 PM
lsvtechatch04
May 8, 2004 03:20 AM
JR Integra
May 3, 2004 04:17 PM
