Also how about Blox B Cams..
How about you research how cams effect an engine and see if you can make an educated guess? Oh, sorry....that would mean you'd have actually taken the time to pull your head out of your *** and read some information on how to put an engine package together....or actually put in the effort to understand that WE CAN'T READ YOUR F*CKING MIND! A SHOCKING EXPECTATION, I KNOW! Does it LOOK like we have enough information in your post to draw a conclusion?
sheesh
Not that we cant presume what is being asked, but it also kinda falls into that whole No Bench Dyno'ing/Bench Racing rule. Plus the word better is very subjectional, a power goal or the applcation of use for the motor would tell us more.
These questions are far easier answered through motivation on ones own part through most of the avalible resources here, thats why we have FAQ's, Sticky's, the Dynothread, etc.
This is more of a survey type question as people who answer are most likely either sole users of Blox or Skunk and cannot give you a comparison. What you do is "count" yay or nays for both, but you'll need to recognize that there could be certain biases such as Skunk users may be more likely to answer or vice versa.
If you are lucky, a real engine builder will come on and give you the skinny.
Conversely, if you want to ask an educated question and you make it clear that you've done due diligence, I'll be happy to give you an answer, some guidance, or point you in a direction.
Till then, however.... I'll tell you to pull your head out of your ***, learn to ask an educated & well thought out question, and stop expecting people to spoon-feed you information.
OR a REAL camshaft guy!
Yes and no, there's a process to follow which is clearly stated in the forum rules sticky'd at the top of this page:
2) Search Feature
The search feature is a great tool to get started. Please try to search first, then ask your question.
Most new people don't read the rules and start posting questions that can be easily answered if they had made some attempt to search before they asked a question. The purpose of doing this is so that the forum doesn't get cluttered up with all to commonly asked questions which people who've been around a long time get tired of answering over and over again. Unfortunately, most of the people that made this forum great have left because of what has been happening and we all suffer from their loss. The ALL-Motor section resembles the model specific forums more now than the technical informative base it used to be. Truely sad...
It isnt quite that bad yet, but yeah it has seen better days.
xbigpitax
69
Mar 13, 2012 12:42 PM
