motor makes a winding noise
Old Mar 24, 2009 | 03:14 AM
my95kink42civic's Avatar
Default motor makes a winding noise
when i give it gas the motor sound like a turbo spooling up not sure what it is
Old Mar 24, 2009 | 04:37 AM
mattliston's Avatar
Default Re: motor makes a winding noise
More information please. Any recent modifications? cold air intake? Breather filter? etc....
From the motor itself, or in the general area? Id have to say a minor exhaust leak or vacuum leak without knowing anything.
Old Mar 24, 2009 | 05:33 AM
R666_EK's Avatar
Yeah probably some sort of leak or extra air being allowed in or out. I just swapped a GSR into my EK and mine does it too. I just have a filter mounted to my throttle body so the vent isn't recirculating back. So just check the vacuum lines first.
Old Mar 24, 2009 | 07:42 AM
Civicthusiast's Avatar
a friend of mine had this problem a while back, while we were driving back from a road trip. the car was an auto nissan.. turned out to be a failing alternator..would make this really odd, kinda screeching sound while driving.. .. don't know if that applies to you.. good luck..
Old Mar 24, 2009 | 08:12 AM
sinepome's Avatar
x2
my alternator got wet or something so it made a "whining,grinding" sound.
or if you have an amp to back spaekers or subs. your rcawires could be too close to your power wire.
there are a lot of things that could "whine" i think we wil need more info.
like where is the sound coming from?
Old Mar 24, 2009 | 08:13 AM
97twodoor's Avatar
Check power steering fluid level, belts, idler pulley's (timing belt pully's included)
rmo
Honda Civic (2006 - 2015)
Jan 28, 2019 07:11 PM
Canadian_EF
Jun 9, 2009 11:16 AM
hondacivic4g
Sep 19, 2005 10:04 PM
hondacivic4g
Sep 19, 2005 08:19 PM
Audio18
May 17, 2002 11:14 PM
