Spring rates/Suspension (yes I searched)
ok I used the search and all I found was some argument (search and youll see)
I am getting ready to do my suspesnion on my 88 CRX
I ordered koni 5 way yellow's. Now I wanted to go with Neuspeed race or eibach. Do either of these companys offer customer spring rates?
I will be putting in a b18c1 and the car will basically be track and auto X with a weekend run here and there.
I was thinking about 500R and 450 Front, I think 500 is the limit of the koni yellow's. So Im just asking around for experiance with spring rates what are you guys on the track and autoX running?
Sway bars? I figure this car should only need a rear one the Stock fron (SI) one looks fine for a FF, I would remove it but I plan on using a cable LSD tranny. So who offers a 22mm Rear Bar?
Any help would be great guys.
Thanks for reading.
Thanks for reading.
Your best bet would be to go with a set of Ground Control coilovers. That way you have many choices in spring rates. 450# and 500# are great choices but will be VERY, VERY stiff on the street crx. I run 400#F and 450#R and it's VERY stiff. I only use the car for autocross, so I dont mind the stiffness.
With 450# springs and a heavy B18 engine, you will probably want to remove the front sway bar all together. My car handles a million times better with no front sway bar and the 22mm rear ST sway bar.
Good luck with your project
Thanks for the help guys, yea that sounds like a good idea I think I will pick up a set of GC's then
Im going to go 400 front and 450 Rear, shold be good to go. Ill install it all as soon as it comes and Ill let ya guys know how it goes. Thanks for all the help.
What do you mean by "5 way yellows?" What are the part numbers you're getting?
AFAIK, off the shelf, there aren't any Koni Yellows for the rear of an 88 that are adjustable while on the car. "8041" is the part number prefix for "on the car adjustable" yellow koni's. The "8040" prefix is adjustable but must be fully compressed to do so.
im in the same boat but ive read that if the front is stiffer than the rear it ride much better so i may go 450f 400r but i duno a lil conf
what are the spring rates for gc's?
saltypants
May 3, 2007 03:14 PM
