Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
winding noise/ transmission ?
Old Mar 24, 2009 | 01:08 AM
ddougss_honda's Avatar
New User
Icon6 winding noise/ transmission ?
2003 civic- 102,000 miles maintainance required lite on but showing no codes. this noise came about 1,500 miles after brake job. doesn't make noise untill about 40 mph, can throw in nuetral and no differance in noise. this is a automatic trans it shifts thru all the gears fine and the fluid is good but it feels like something is holding the car back, slows fast when letting off the gas. I hope someone can help
Old Mar 24, 2009 | 02:30 AM
ch0baca's Avatar
Default Re: winding noise/ transmission ?
You have a frickin civic, go to the civic forum omg
Old Mar 25, 2009 | 05:45 PM
Carcrazy1
Guest
Posts: n/a
All I can recommend is all you have to do is must suddenly go directly to a civic company to fix your problem rather than taking advises from forums.
Old Mar 28, 2009 | 07:25 AM
BLKFLSH's Avatar
Sounds like a wheel bearing or drive shaft problem. Jack the car up, and turn each wheel by hand (put the tranny in neutral to turn the front wheels with the emergency brake applied). Put the tranny in Park, and release the emergency brake to turn the rear wheels. If you hear or feel something different on a certain wheel, you've found the culprit.
uhhkilleez
Apr 23, 2012 03:43 PM
2gnarly
Jun 26, 2011 09:43 AM
vigorhy
Mar 20, 2008 03:54 PM
Homer_Simpson
Mar 21, 2002 12:35 PM
