losing coolant
Old Mar 23, 2009 | 11:39 PM
ROSSIL25's Avatar
New User
Icon6 losing coolant
i have an 97 integra i had a little accident n my radiator got vented a little. and now im losing coolant. every 2 weeks i have to put coolant. I taught it was the radiator but i dont see the radiator leaking what can it be some one help.
Old Mar 24, 2009 | 07:06 AM
mouab18c1's Avatar
Default Re: losing coolant
check to see if your leaking elsewhere. also check under your oil cap to see if you have milky substances...if you do it could be a bad headgasket or just a simple leak somewhere
Old Mar 24, 2009 | 07:34 AM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Fill it up with coolant when it's cold. Let it run til normal operating temperature and look for leaks all around the rad and hoses.
Check your oil cap^^^
Old Mar 25, 2009 | 01:21 AM
my_hidden_romance's Avatar
AGREED check the oil cap... if its milky i bet i know where the lost coolant is
Old Mar 25, 2009 | 04:19 AM
imroadk1ll's Avatar
i got this same problem i thought it was normal i dont know where it all goes ill try and see where its going
Old Mar 25, 2009 | 05:30 PM
b18c1ej8's Avatar
Yeh i feel liek i have a similar problem except the motor is a brand new b20 (9.6:1) from Hmotors. We pressure tested the motor and my compression is even all across. I don't really know any other ways to diagnose losing coolant. I know everyone will respond to me by saying to check to see if the coolant and oil are mixing, they are NOT mixing.
Teamdiesel
40
Dec 3, 2019 04:10 PM
hondaOchibi7
May 2, 2011 10:07 PM
mightyone
Nov 4, 2003 10:53 PM
ClubSiRacer
Apr 23, 2003 12:08 PM
