Clutch Slippage on 97 Prelude
Hey Guys
I'm new here and I have a question about my 'lude... Maybe someone out there can help me figure out what the deal is. Here goes..
I have a 97 non SH Prelude with the following mods,
AEM Cold-Air Intake
Skunk2 Intake manifold
SKunk2 Tuner I Cams
Skunk2 ProSeries Cam Gears
DC Sports 4-2-1 Headers
APEXi N1 2.5" exhaust
AEM Pulleys
EXEDY Stage2 Clutch
ACT Light-Weight Flywheel
HONDATA s300
Tuned at Church's Automotive Testing - 218hp @ 7300rpm; 178 lbs-ft @ 5500
So during the tune on the DynoPack the clutch started slipping. It hadn't before and I only got the Exedy clutch and the ACT flywheel last year and it hasn't been slipping at all. After the tune, when I drive it hard and shift so that as soon as I'm in 2nd gear the car is already in VTEC, then the clutch slips for about 2-3 seconds and then catches. The same for 3rd gear. What could be the problem? DO I need a new clutch and why would that happen in less than a year?
Thanks guys!
-Wu
AEM Cold-Air Intake
SKunk2 Tuner I Cams
AEM Pulleys
EXEDY Stage2 Clutch
HONDATA s300
Thanks guys!
-Wu
Are u sure its Slipping or hesitating.i've had a few and changed the clutch same thing...ended up being a clogged EGR..so u might want to check that...my SH is doing that right now...i know it isnt the clutch, i drove it hard and nothing only when i baby the car it hesitates
I wanna thank you cause Ive been trying to find out why my car slips through 2nd for the past year and I had a missfire on all 4 cylinders, one of the codes was the egr. Thank you.
