Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Rough Gas Pedal
Old Mar 23, 2009 | 07:50 PM
benji7288's Avatar
Default Rough Gas Pedal
So i've noticed that my gas pedal seems rough. Before, the gas pedal went down smooth. But now, i have to give it more pressure, it seems that it's stuck then it engages, but i have to do it soft otherwise it'll go full throttle. When the car is off, the pedal is real smooth. I checked under the hood n the hook on the throttle feels just like the pedal. Any idea what might b going on here? Already added WD40 on the throttle body cable n it didn't work.
Old Mar 23, 2009 | 10:15 PM
DynastyRacer22's Avatar
Default Re: Rough Gas Pedal
i got the same problem
Old Mar 24, 2009 | 06:21 AM
iplayloudly's Avatar
sounds like maybe the butterfly in the throttle body is sticking. I had that problem with my old del sol. A friend of mine gave me a spare throttle body he had, and that fixed it.
Old Mar 24, 2009 | 01:54 PM
Targa250R's Avatar
be professional
Try cleaning out the throttle body with carb cleaner.
Old Mar 24, 2009 | 07:21 PM
i'll try that or maybe a leaf or something got clogged ive never changed out my stock filter either lol
Old May 22, 2009 | 09:39 AM
Mindless Mind's Avatar
So I've noticed on my Civic that my gas pedal is difficult to push down when I first start my car. When it's off, and I push on the gas pedal, it goes down maybe half an inch then seems to get caught forcing me to push down harder. At this point I can hear a small clicking noise as if the pedal itself needs lubricated or something. Once I put in the extra effort, it works fine throughout my whole drive. It's just the beginning part that's starting to annoy me, especially in my residential area where people look at me strange when my car sounds like I'm one of those ******** who speeds around everywhere cause I have to put more force on the pedal.
I did a search and found this post, and was wondering if you guys think this is my problem, or if it's something else.
Regards,
Old May 22, 2009 | 09:46 AM
R134's Avatar
Happened to both of my cars. Turned out the throttle body had some gunk around the butterfly. Cleaned them with carb cleaner, problem solved.
Old May 22, 2009 | 10:17 AM
Ok. I'll give that a try. Thanks.
Old May 22, 2009 | 11:04 AM
changed out my stock filter and cleaned up the throttle and now its alot better
Juniorhatch
May 9, 2011 11:51 AM
85crx509
Sep 3, 2008 11:10 AM
IsweatHONDA
Jul 14, 2006 12:06 PM
HipHop Junkie
11
Mar 10, 2005 11:23 PM
