Need Help: Blower Motor
Old Mar 23, 2009 | 06:59 PM
mpls's Avatar
Default Need Help: Blower Motor
The blower motor in my 94 Integra stays on when the car is shut off and the climate controls setting turns on when pressed as well. I replaced most of the fuse under the hood and checked all the fuse under the driver side and none seemd to be blown. I search but nothing for solving this problem. WTF can be the problem?
Old Mar 23, 2009 | 09:52 PM
dtapia's Avatar
Default Re: Need Help: Blower Motor
check the fan relays on the radiator. we have seen a few come thru the dealer with the same problem eneded up finding the relay shorted to power side and keeping everything powered up on that circuit.
Old Mar 23, 2009 | 11:17 PM
syknxv3's Avatar
is the blower motor connected directly to the battery, my car used to be like that, till i just relayed it
Old Mar 24, 2009 | 04:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Are you talking about the heat/AC blower under the dash, or the radiator fans? If it's the blower, you probably need to replace the resistor unit located inside the blower motor housing.
Old Mar 24, 2009 | 04:45 AM
mpls's Avatar
its the blower motor under the dash. When the key is out and I turn it to the settings 1,2,3, and 4 it comes on. Changed fuse and relays but nothing works. I dont mind it but I dont want to forget to turn it off one day and later find out that it drained the battery. But I'll check the resistor. Thanks.
Old Mar 24, 2009 | 07:18 AM
mpls's Avatar
up any one
Old Mar 24, 2009 | 11:28 PM
alonsobuiltmotors's Avatar
i have an ek blower motor if u end up needing one but check the climate control
Allen Harris
Nov 20, 2016 07:00 PM
92LXcb7
Mar 8, 2012 03:42 PM
kittchong
Aug 2, 2011 07:02 AM
unclejemima
Jul 19, 2004 04:32 PM
