Rear crx glass on hatch needs fixn'
Old Mar 23, 2009 | 06:58 PM
slmd2ndgen's Avatar
Default Rear crx glass on hatch needs fixn'
So I have a broken rear hatch window. Picked up a new hatch and need to swap it. Tried searching for advice but no luck. Anyone replace this before?
Old Mar 23, 2009 | 07:18 PM
jhammond_82's Avatar
Reject Papi
Default Re: Rear crx glass on hatch needs fixn'
not sure bout the crx but my hatch is only 4 bolts. just when your putting the new one on, line up the body lines as evenly as possible so your seals work, and then tighten down the nuts.
Old Mar 23, 2009 | 07:24 PM
slmd2ndgen's Avatar
Ya, I wanted to keep the large hatch intact, and only change the shattered piece shown in the pic.. It's the glass that the third brake light shines through.
Old Mar 23, 2009 | 07:31 PM
Reject Papi
oohh, i didn't even notice that. lol. when my tail lights were pulled the plastic on the inside of the hatch had to be removed, then little tabs held it on. most of them broke so i'm going to use 3m ****.
Old Mar 23, 2009 | 07:36 PM
JDMgunmetalCRX's Avatar
dude thats the coolest part about the honda crx! fix det mug!
Old Mar 23, 2009 | 08:42 PM
slmd2ndgen's Avatar
I'll take it to a auto glass place and try to get a recommendation. Checking with my repair manual, it's not clear, but it seems like the small section of glass needs to have the seal "cut" out then a new bead of seal laid down. One step at a time, next should be the door seals and window rubber.
Old Mar 23, 2009 | 09:26 PM
scottmog's Avatar
Let me know via message if the rear windshield glass is for sale. I'm looking for one with no scratches at all.
Old Mar 24, 2009 | 03:00 PM
slmd2ndgen's Avatar
Will do, I shouldn't have a need for it.
Old Mar 24, 2009 | 03:20 PM
mitsubishiv5's Avatar
im pretty sure youd have to cut through, just as the manual says. should be like the rear hatch itself as well as for the front windshield.
when you replace the quarter moldings youll have to remove the whole quarter glass and get it reinstalled. it cost me 30 a piece for every window for installation and 38 a piece for each quarter molding. well worth the price since it was getting faded and old.
Old Mar 24, 2009 | 03:21 PM
if you provide the glass shop with your glass as well as moldings they typically do it for cheap as its only "labor"
Vagitarian
11
Jul 4, 2013 01:02 AM
mike11
Northern California (Sales)
Feb 7, 2012 08:43 PM
carlthecrx
May 21, 2007 03:47 PM
b16acrxer
Dec 7, 2003 11:25 AM
