93 integra wont stay running help(vid inside)
Old Mar 23, 2009 | 05:57 PM
teknohatchie91's Avatar
Default 93 integra wont stay running help(vid inside)
Hi, my 93 integra its not stay running and im thinking its the alt but im not sure so here i made a vid so u guys can help me figure this prob out. i checked for grounds already, Bad alt fuse( I checked the fuse inside the cabin, not sure where the or if there is another alt fuse) and my bat is good. here it goes
Old Mar 23, 2009 | 06:30 PM
Default Re: 93 integra wont stay running help(vid inside)
vid and no help?
Old Mar 23, 2009 | 07:35 PM
B17chris's Avatar
check sum vacume lines on the intake manifold and work with it and see what u find mabe u shoud check ur i.a.c idle air control valve mebe u should try to clean ur throtle body theres a list to go down and i dont thinks its the alternator... hope im of sum help good luck
Old Mar 23, 2009 | 07:42 PM
capn's Avatar
to see if it is the alternator hook a voltmeter to the battery, take note of the voltage, start the car. The voltage should raise to at least 13-14.5 volts, if it is not doing this then it is clearly a bad alternator.
Old Mar 23, 2009 | 08:54 PM
stocker2shocker91's Avatar
I requested a short story for a title.
if there is something wron with the charging system the battery light will stay on..i would say there is a crossed wire or ground since it dies when you hit the lights off..if anything it would die when you turn the lights on
Old Mar 23, 2009 | 08:57 PM
your first step needs to be checkin that code...the ecu is in safe mode which is why you can rev higher than that...pull that carpet back and see what the led is doin
Old Mar 23, 2009 | 09:50 PM
szczerbanator's Avatar
Haha you sound soo stupid, ESL?
Old Mar 23, 2009 | 10:35 PM
b18integraboy's Avatar
just jump the Ecu so you can get a code.
Old Mar 24, 2009 | 08:51 AM
yeah i dont sound too cool but i dont think anyone likes there voice when they takes vids of them talking, so i dont really give a **** if i sounds stupid i just want to fix my car and thanks for everybodys responses i will check my ecu and check for codes.
Fall of Atom
Jan 7, 2014 07:21 PM
sinisfun
Feb 14, 2007 03:47 PM
sinisfun
Feb 14, 2007 02:09 PM
chadmasterc
Jul 29, 2003 02:11 PM
Proper
Sep 13, 2002 09:29 AM
