Is this Weldon FPR the correct one to use with T1's 1000cc ID injectors...
I have T1's 1000cc Injector Dynamics injectors and will be running over 120psi of fuel pressure. Is this the FPR that most guys run?
http://www.dawesmotorsportsstore.com...ducts_id=17808
I spoke with a guy at Weldon about this a month ago or so, according to him you want the regulator with the part #A2040-281-A-120
"Thank you for your inquiry – the -120 will be fine. However, if you believe you’ll increase your base pressure to anything over 110, I’d go with the -200. I’ve got both versions in stock or you can order through any one of my distributors listed on the website.
Thanks again,
Jim Craig – Weldon Racing Pumps"
Thanks again,
niedejb
Mar 28, 2002 02:06 PM
