Doin rear discs on my 00 EX, master cyl and prop valve questions?
Old Mar 23, 2009 | 02:36 PM
GetawayInMoscow's Avatar
Default Doin rear discs on my 00 EX, master cyl and prop valve questions?
Okay when I did this on my EG I used the master cylinder off of a 1991 EX as per B18C5-EH2's directions, and a 40/40 proportioning valve.
Now I'm getting ready to add rear discs on my EX, I keep finding conflicting information.
Do I need a proportioning valve and master cylinder from a 99-00 SI or is it all the same?
From searching it seems the CX, DX, LX, HX, and SI are all the same proportioning valve but the EX is different? (makes no sense to me)
What about the master cylinder?
Old Mar 23, 2009 | 02:41 PM
98civdx's Avatar
Master Detailer
Default Re: Doin rear discs on my 00 EX, master cyl and prop valve questions?
you dont need the prop valve, but for best resultsts you NEED it.
if i was doing it i would definetly use them
im a little confused by that as well you would the si and ex would be the same because they have rear disk and not any of the other ones.
Old Mar 23, 2009 | 03:55 PM
94EG8's Avatar
Seagull Management
CX and DX hatch, as well as HX and Si coupe all share the same prop valve. DX and LX sedans are different again, but the same as each other, EX coupes are different again. Just pull one from a hatch, easy to find a should be fairly cheap.
EXs are different because they use large front brakes and rear drums.
Old Apr 9, 2009 | 11:26 AM
evilhonda's Avatar
ok, so if you already have one, how do you tell what model the prop valve is from? they all look alike
Old Apr 9, 2009 | 04:48 PM
94EG8's Avatar
Seagull Management
'92 - '95 civic and '94 - '01 Integra at least are stamped on the valve, its very small and hard to find.
Old Apr 9, 2009 | 04:52 PM
NightCat's Avatar
could I run GSR disks with an EX Prop valve? would it work at all?
Old Apr 9, 2009 | 04:54 PM
It would work but you should get a DX, LX, SI, HX, whatever prop valve.
Old Apr 10, 2009 | 04:05 AM
evilhonda's Avatar
what about 96-00 civics?
Old Apr 10, 2009 | 06:18 AM
B16aCRXSi's Avatar
if your using rear disk conversion you usally want to get a 40/40 from an integra or Si distributes the brakes the right way on disk brakes, lx dx ex had drums which means they used 70/40 i think it is or something like that which makes your brakes like **** if your using rear disk brakes. drums and disk brakes are diff as are the prop valves that go with them, I should know im using my stock 92 cx prop valve on GSR conversions and im pretty much stopping with only my front brake.
Old Apr 22, 2009 | 07:45 PM
983stage's Avatar
New User
I just did a full gsr brake conversion on my 98 cx. First off what brakes are you putting in, your ex should already have rear disc brakes. If your car doesn't have rear discs and your putting in the standard civic or integra rear brakes this is what you'll need.
1)99-00 Civic Si Prob. valve. Acura Prob valve won't bolt to firewall.
2)7/8th civic ex or si master cylinder should be fine. I am running the same for GSR brakes. Don't get the 15/16th acura mc unless you are replacing the brake booster as well.
3)You should also get rid of your front brakes and replace them with larger 10.3in rotors from a civic Si, ex, or acura integra. 80% of braking is up front.
Can you clarify what car you have and exactly what brakes are being put in.
Old Apr 22, 2009 | 11:02 PM
mario_pic's Avatar
if u got a 99 ex with abs u just swap in the rear disk on need to swap out the prop valve and master cylinder because if u look up the prop valve and master cylinder to 99 sir there the same becasue sir came with abs and the prop valve is the same model # no matter what model the car is from 96-00 there all the same the master only changed only just check it the master reads 15/16 if it does ur good to go i if u want use integra rear disk with abs if u want to retain ur abs eney integra from 91-00 will work just dont use the toe, lca and camber arms only rear trailarms only because if u use the integra lsa's and stuff it will throw ur alignment out of wack
Old Apr 23, 2009 | 03:57 AM
94EG8's Avatar
Seagull Management
'96 - '00 civic hatchbacks share the same prop valve as the Si Coupe, they aren't like the '92 - '95 civics which required swapping the prop valve with a non ABS integra unit.
No '96 - '00 EX had rear discs, as a matter of fact the only '96 - '00 USDM civic to get rear discs was the '99 - '00 Si.
Its an EX, he's already got large front brakes
*sigh* again, the CX & DX hatchbacks as well as the HX and Si coupes share 1 prop valve. Other 6th gen civics use different prop valves though.
TwoFaced
Feb 22, 2011 12:04 PM
92'si
13
Mar 31, 2009 03:35 PM
SmoothCTR
Aug 30, 2007 08:37 PM
