Clutch or Tranny problem
Old Mar 23, 2009 | 01:43 PM
aarsen43's Avatar
Default Clutch or Tranny problem
makes a growling noise in all gears when i pull up the clutch. also the clutch feels weird when i pull it up. like it is springy in an area and doesn't pull up smooth. i think teh recent guy did a own clutch job and ****ed it up.
any advice would be great. thanks
Old Mar 23, 2009 | 02:14 PM
johnnyonth3spot's Avatar
Default Re: Clutch or Tranny problem
Drop your transmission its not really that bad. The only real hard part is when you put the tranny back on getting every thing to line up while lifting it into position. I would check the pressure plate though.
Old Mar 23, 2009 | 03:18 PM
sanimalp's Avatar
$cat /dev/urandom
my guess? your throwout bearing return spring is broken. I usually buy 3 of them at a time, because they are broken every time I do a clutch job on an ef. I have even seen one that broke off a tab of the throwout bearing and sheared off the end of the return spring. It is #5 in this picture.. the tab i was talking about is that bit on #1..
JDM3STAGEVTEC
Dec 19, 2008 07:43 PM
Rick James
11
Nov 4, 2008 07:00 PM
tony88crx
Jun 21, 2005 06:37 PM
CimorelliCRX
Dec 15, 2002 04:02 AM
greensleeper
Jul 31, 2002 02:33 PM
