Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Front right brake is humming??
Old Mar 23, 2009 | 11:42 AM
j_peng4596's Avatar
Default Front right brake is humming??
So as some of you have already read. my civic was hit about two weeks ago. it seems that the other car ran right into the front driver side tire. leaving the wheel turned
now the brake seems to be humming....... it doesnt always happen, usually after lots and lots of braking before it begins to hum
any help?
Old Mar 23, 2009 | 11:54 AM
aLlmoTorcoUpe's Avatar
Default Re: Front right brake is humming??
will check where the brake caliaber is. now u know where the brake pad set. there is a little metal plate that the brake pad sets on. it should have be bent. because that has happend to me on the driver side front. it was mating so funny humming. will just take a look at the metal plate where the brake pad sets on, check the top and bottom. need u to see very close on that.
Old Mar 23, 2009 | 11:55 AM
Old Mar 23, 2009 | 11:57 AM
mybad on the quote post. it was to be one but came out 2 of the same
logg_frogg
Mar 8, 2008 02:58 PM
stuie08
Dec 13, 2006 03:24 PM
