Wheel Knock Noise
Old Mar 23, 2009 | 08:02 AM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default Wheel Knock Noise
i have a 96 integra that i use at my DD is automatic with abs and lowered
only when i am on the throttle and moving i have a knocking noise from what sounds like the front left wheel. i replaced the left cv axle but knocking is still there.
could this be the wheel bearing? ne help please
Old Mar 23, 2009 | 08:25 AM
mouab18c1's Avatar
Default Re: Wheel Knock Noise
to check if its your wheel bearing jack up your car and see if there is any play in your tire...if there is then your wheel bearing is out...and check again if there is any play in your axle
Old Mar 23, 2009 | 09:48 AM
SIR EF9's Avatar
had the same thing happen to me before u get all worried... CHECK OUT YOUR LUG NUTS!!!! the idiot that put mine on... left them loose!!!
Old Mar 23, 2009 | 10:18 AM
SuzukaBlueAP2's Avatar
I would check all of those. Lug nuts...axle nut...wheel bearing...even the tie rod end and ball joints.
Does the 'clunk' change when making a turn? Is it always there no matter what direction you are traveling?
Old Mar 23, 2009 | 11:38 AM
bakertime's Avatar
If it happens on a bump at all...check upper and lower ball joints also. Also take a look at the bushings all around.
Old Mar 23, 2009 | 03:26 PM
ruskiy's Avatar
X2
jack it up check all nuts, grab the tire at 3 and 9 o'clock and pull on one side while pressing on the other then do same for 12 and 6 o'clock positions. If not sure as to how much play it should have try the other tire.
Old Mar 23, 2009 | 03:58 PM
Bluesiff's Avatar
Hell, it might even be a broken belt in the tire itself. Just feel around and you might notice part of the tire is bowed inward.
Old Mar 23, 2009 | 05:50 PM
hondateg10's Avatar
thanks for all the info.... bluesiff i noticed when i had the tire off i could hear something inside the tire.... lug nuts are tight... when i turn to the right i dont hear the noise as bad as i do when i turn to the left but no matter what i still hear it when going straight and only when i am on the throttle
Old Mar 24, 2009 | 09:59 AM
hondateg10's Avatar
ttt
Old Mar 24, 2009 | 10:01 AM
HondaHeddie's Avatar
does it pull to one side when you hit the brakes?
Old Mar 24, 2009 | 10:54 AM
hondafreak08's Avatar
i know from 1 bad experience lol ... it could be your intermediate shaft that goes from the driver side axle into the tranny, make sure the bolts are tight ... good luck
Old Mar 25, 2009 | 05:04 AM
hondateg10's Avatar
i didnt think to checked the midshaft out. i will have to do that....
does not pull when i hit the brakes
Mr.Chow
Oct 3, 2011 07:54 AM
David12
10
Nov 15, 2009 01:35 PM
NeWsCr
Sep 11, 2006 01:26 PM
Ronin Integra8
Dec 14, 2002 04:16 AM
GeeSeeR
Aug 4, 2001 03:07 AM
