FS B16, whole or parts, an d16 viatri pistons an springs
. Motor has less then 20k on it since rebuild, but one of the cylinders is low on compression, like 80psi So a bore, an new set up pistons will be needed.
The goods, eagle rods, srp pistons 81.5 bore with 9 to 1, has clevite bearings an oil pump was fresh at rebuild. ARP main an Head Studs, Head skunk2 dual valve springs an retainers, stock b16 cams in it . Oh yeah has cylinder brace also. Stock intake manifold is also avaliable. Head was checked when block was built, i found my reciept for work done to block an head, i 4 got but it had new valve guides an valve job done. Block was also line bored with the new arp main studs installed. I have a stock exhaust mainfold, and obd2 dizzy, an stock obd1 intake an throttle body, minus sensors, can probally find the stock injectors if a guy wanted them. Looking for 1,000, lets talk, i will part if the head sells.
Up next is a set of bnib vitari ycp pistons with rings, d16 standard bore, 9 to 1 ratio. I got 125 in them, just wanting my money back, also have a d16a1 block an a z6 crank if a guy is interested in it.
Also for sale is a set of comp cams valve springs for a d series. part number, 912-16, spring rate of 50lbs when valves r closed 170lbs when opean, make offers
how far can you bore b series stock sleeves without sacrificing strength? i thought ya didnt want to go over 81.5mm?
^ I don't know to tell u da thruth, depends on how much boost an your tune really, I was debateing about boring it over an going all motor if it doesn't sell.
1qucksol
Nov 25, 2009 09:42 AM
1qucksol
Nov 25, 2009 04:41 AM
